4 Pages«<234
wb2tbb
#31 Posted : Monday, March 14, 2011 10:06:30 AM(UTC)
wb2tbb
Originally Posted by: magician59 Go to Quoted Post
Not as easily as the front legs.
Can you tell me how the back removes?
If it is not resonable, I will just level with the front and leave the rubber foot off the back.
wb2tbb
#32 Posted : Thursday, May 26, 2011 6:27:55 AM(UTC)
wb2tbb
Hello....Back in January, you helped me fix my washer, by suggesting the bearing kit....
AP4009132 (12002213) Thrust bearing kit 1 23.99
That did the job!
Now, suddenly it is having a brake problem. When it needs to spin, motor hums loud...might smoke, or blow that outlet's circuit breaker. After many hours...when the water is cool. It will start, but takes a long time to speed up, and makes a lot of noise, with "hot" smell . I am guessing that my choice in washers during the thrust bearing kit install was not correct, and the brake is not releasing. I remember when I installed the C clip, it went in...but did not seat properly. It held everything in place, so I left it alone. Perhaps now it bent, or seated by itself...and now the brake is hitting when it shouldn't??
Any suggestions what I should check. or do?
Thanks!
.....Dave
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Maytag MAV7600 will not spin a full wash load (Washer Repair)
by dfab 10/14/2022 11:13:21 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool LAT2500AAE Washer agitates one direction only and will not spin (Washer Repair)
by spmelick 3/21/2022 4:02:10 PM(UTC)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
Cabrio will not spin or agitate (Washer Repair)
by Johneb06 1/19/2021 2:52:49 PM(UTC)
Kenmore Front Load Agitates, but will not spin (Washer Repair)
by krusen 1/2/2020 7:56:09 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Maytag MVWX655DW0 will not spin (Washer Repair)
by radams925 6/29/2019 9:50:29 AM(UTC)
Maytag A9200 Will Not Spin (Washer Repair)
by spirittoo 10/31/2018 1:58:04 PM(UTC)
GE no faults, will not spin on regular wash (Washer Repair)
by dekk_ks 3/28/2018 8:23:06 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
4 Pages«<234
