AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Top load frigidair washer.How to separate transmission from tub?Trunnion screws were
:) How do I removed the transmission assembly from the tub. Trunnion screws already removed. Just can get the shaft to slide out.What else needs to be removed?
Thank you very much for your help.
Glad to do it, good luck!
Washer Repair
