AtC
#1 Posted : Friday, October 10, 2008 4:33:07 PM(UTC)
AtC
Hello. Question is about the water that is filtered and dispensed by my fridge. It is never cold. I would assume that the water would go through the fridge in some fashion and be cooled more regularly. Does anyone know of a way to get better/more efficient cooling of the drinking water? Ideas I have considered:
1. Add additional tubing the water would flow through in the bottom of the fridge.
2. Add a reservoir of some sort.
3. ???
Maybe I am looking at the problem completely wrong, which is why I am posting this question here. Any thoughts/ideas would be greatly appreciated. Thanks.
libertyappl
#2 Posted : Friday, October 10, 2008 8:26:27 PM(UTC)
libertyappl
Please post your model number off the unit.
Nat
AtC
#3 Posted : Saturday, October 11, 2008 5:24:50 AM(UTC)
AtC
ksrj25cnst01
libertyappl
#4 Posted : Saturday, October 11, 2008 6:10:48 AM(UTC)
libertyappl
Do you use the filtered water a lot?
Most units with ice & water are hooked up to the hot water line, which they should be. What is the temp for you heater set at?
Nat
AtC
#5 Posted : Saturday, October 11, 2008 9:17:50 AM(UTC)
AtC
Yes, we drink a lot of the filtered water out of the fridge. I will have to check the temp of the hot water, but it isn't too high in the summer months (and things are just starting to cool down here now.)
