AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer heats intermittently,clothes not drying properly
You have been a member since:: 3/12/2011(UTC) Posts: 2
our clothes are not drying properly.it will heat for 30 seconds then not heat for 1 minute then heat again for 30 seconds etc. i have cleaned all the vents including the back of the dryer housing.any suggestions. thanks
Originally Posted by: keithblake@peoplepc.com ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) our clothes are not drying properly.it will heat for 30 seconds then not heat for 1 minute then heat again for 30 seconds etc. i have cleaned all the vents including the back of the dryer housing.any suggestions. thanks could be thermostat or bad ventilation,check door gasket and if hose are sealed tight
Dryer Repair
