ulremember
#1 Posted : Saturday, March 12, 2011 8:54:49 AM(UTC)
ulremember
Hello to all.
My question is this:
How hard is it to replace the relay at the compressor of mentioned refrigerator?
I had a call to check out refrig due to it was not getting cold. I proceeded to remove the relay cover on compressor and wiggled the white wire I believe and the unit started. I doubled checked it operation by turning the defrost timer to cycle compressor. It did not come back on. So I wiggled the wire again and after about thirty seconds, the compressor started. So I am assuming it is the relay.
Any other suggestions are greatly appreciated!
Blessings
Ulremember aka Chuck Butler Jr.
#2 Posted : Sunday, March 13, 2011 3:22:56 AM(UTC)
I would replace the following compressor parts AP2061490 Klixon and AP3156242 PTCR device. Also, you will need to replace all burnt wires and spade terminals.
