About a month ago our Bosh DW door would not latch closed. After researching, I learned how to manipulate the plastic pieces inside the door so the mechanism would "snap" back into place and latch correctly again. We run a cycle about 3x a week, and beginning last week the door became a little hard to close, although it would latch successfully with a medium push. But then we started noticing that after a cycle completed, the soap powder was still in the container despite the container door actually being OPEN. The soap in the open dispenser was wet and caked in there. This has happened 3 times now. Is the door opening very late in the cycle or something? Around the same time, we also noticed a funny spray noise coming from the DW during operation, as if water was hitting a stainless steel bowl inside...but it does this even on an empty load. If I open it mid-cycle, I see water coming out of the upper spary arm, but the arm doesn't appear to be spinning. I've taken a part both arms, and both are clean and spin freely when spun manually. Not sure how to fix this and wonder if the latch issue is connected to these soap and spray noise issues...I appreciate GRATELY any help!
