danowski
#1 Posted : Thursday, October 9, 2008 9:47:30 AM(UTC)
danowski
My washer overfills. The water cuts off when I shut off the machine. When I blow into the pressure hose I hear watter bubbling so I assume it is not clogged. Should I assume the pressure switch is bad and replace it or should I look for another problem?
libertyappl
#2 Posted : Thursday, October 9, 2008 10:54:43 AM(UTC)
libertyappl
It norally is either thr pressure switch or the tube. Make sure there are no cracks/holes in the tube as well as no water inside the tube.
Nat
danowski
#3 Posted : Thursday, October 9, 2008 11:06:20 AM(UTC)
danowski
How do I make sure there is no water in the tube? It is solid black not clear.
libertyappl
#4 Posted : Thursday, October 9, 2008 3:34:47 PM(UTC)
libertyappl
Remove the ends and blow thru it.
Nat
