3 Pages<123>
lmmtz1
#11 Posted : Thursday, October 9, 2008 10:20:22 AM(UTC)
lmmtz1
thawed the tube over a week ago and still no ice am I getting you confused
lmmtz1
#12 Posted : Thursday, October 9, 2008 10:30:32 AM(UTC)
lmmtz1
I have also checked the voltage at the [FONT='Calibri','sans-serif']Solenoid and nothing but when I used the water dispensor the other solenoid does get voltage to open.[/FONT]
v2k04
#13 Posted : Thursday, October 9, 2008 10:36:46 AM(UTC)
v2k04
sometimes when that tube gets frozen the pressure will pop off the 1/4 in tubing going to the fill tube and when it calls for water it leaks on the floor you can test that valve 2 ways 1 put 120 volts directly to the valve or use your ohm meter and read if its open if you read nothing on the high scale of your meter the valve is bad if you read some resistance its prob ok. you can cycle that icemaker by putting a jumper between T & H if it has the module style icemaker
lmmtz1
#14 Posted : Thursday, October 9, 2008 11:22:58 AM(UTC)
lmmtz1
all looks good so have u ever seen that relay go bad. I jumperd it and still no water flows to the ice maker. thanks for all ur help
v2k04
#15 Posted : Thursday, October 9, 2008 11:24:09 AM(UTC)
v2k04
yep replace the valve
lmmtz1
#16 Posted : Thursday, October 9, 2008 11:28:59 AM(UTC)
lmmtz1
it is a dual valve both water and ice water come off same valve and water is working fine
lmmtz1
#17 Posted : Thursday, October 9, 2008 11:45:00 AM(UTC)
lmmtz1
so u don't think it is part # AP3865282 relay capacitor that could of gone bad. Do you know if that part is on the inside? and also is it just a plug in module?
v2k04
#18 Posted : Thursday, October 9, 2008 12:50:05 PM(UTC)
v2k04
if it's a dual valve they are separate.... what is the model # on the frig
v2k04
#19 Posted : Thursday, October 9, 2008 12:55:02 PM(UTC)
v2k04
Why don't you just call me I'll walk you through it 402-984-8747
lmmtz1
#20 Posted : Thursday, October 9, 2008 1:08:08 PM(UTC)
lmmtz1
DRS2662AW is the model number. It is a single valve with dual outlets 1 for water and 1 for the ice maker water.
Guest (13)
3 Pages<123>
