smcraw
#1 Posted : Thursday, October 9, 2008 5:35:58 AM(UTC)
smcraw
I believe my washing machine motor gets overheated when it kicks into the high rpm spin cycle. It happens even when the machine just has water in it, so it isn't an overweigth issue. What are common issues or problems that I can check?
Thanks,
Stephen
v2k04
#2 Posted : Thursday, October 9, 2008 8:17:48 AM(UTC)
v2k04
If it overheats to the point of kicking off the overload and won't restart for an hour or two until the motor cools down you need a motor it will also pull higher amperage than norma lif the motor is bad there is a rating tag on the motor what amps it should draw
