CJRLMPLS
#1 Posted : Monday, October 8, 2007 11:31:46 AM(UTC)
CJRLMPLS
This drier stopped working for the second time - I had replaced the non-resettable thermal fuse about 4 years ago and all had been well.
Two days ago the same thing happened - except this time. after it stopped, my wife checked a couple of things then walked away from it. About 30 mins later, she smelt 'hot metal', checked it and discovered it was extremely hot. To cut a long story short, I unplugged it, went and got a new thermal link, replaced it then plugged it back in. The heater IMMEDIATELY came on - the door was open and the motor was not running. I pressed the start button - the motor started and the drier appeared to work.
Apparently the interlock that prevents the heater from being powered when the motor/fan is not running is dead.
Where is that interlock? Is it part of the motor switch? Is it an airflow detector vane in the fan path? The diagram I have is not specific. Wahat do I need to buy?
Anyone got any ideas?
Thanks!
#2 Posted : Tuesday, October 9, 2007 1:08:05 PM(UTC)
Your motor switch shorted and they do not sell the switch, you have to buy the whole motor. That part # is AP3094245
CJRLMPLS
#3 Posted : Tuesday, October 9, 2007 5:12:35 PM(UTC)
CJRLMPLS
Thanks! I'd kind of figured that out - went to Sears this lunchtime - found the motor with the pluggable switch securely attached. Why? The motor still works - ah well!
I'm now deciding whether I want to invest the $110 or so in the motor plus the aggravation of installing it - or just give up and get a gas dryer!
Thanks for the help, tho'
#4 Posted : Wednesday, October 10, 2007 12:47:58 AM(UTC)
I share your disgust; I pull the switches off these when I junk them, have a few lying around; would never sell one, but would use one in a repair!
Main Control Board - Fire Hazard? (Dryer Repair)
by Highlander2017 10/6/2017 6:58:31 AM(UTC)
Normal for heating element or fire hazard? (Dryer Repair)
by NWHomebody 12/6/2010 11:51:35 PM(UTC)
