sparky2011
#1 Posted : Thursday, March 3, 2011 6:04:24 PM(UTC)
sparky2011
my dishwasher doesn't seem to dry. I changed the element and still nothing. what now
#2 Posted : Friday, March 4, 2011 2:37:32 AM(UTC)
Replacement parts for FRIGIDAIRE FDB2810LDC1 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154495501ena.pdf
I would check the hi-limit thermostat, should be 0 ohms.
Joe / APP Team
#3 Posted : Wednesday, March 9, 2011 11:07:58 AM(UTC)
Joe / APP Team
Originally Posted by: denman Go to Quoted Post
http://manuals.frigidaire.com/p...Kinston/154495501ena.pdf
Sparky,
With your multi meter, check the hi limit thermostat for a closed circuit(below 200 dgrs.) like the previous post.
You can program the test mode and the last 90 seconds of the test will send power to the thermostat and element, the element should be warm if you open th door at the end of the test mode(if the control board is operating properly).
Were it me I would perform a "live" voltage test,
You may or may not want to ?
(be extremely careful if you do)
You'd attach one meter lead to a chassis ground. and the meter set to read AC voltage, check each wire/terminal for 120 VAC from the terminal to chassis ground, starting at the red wire on the hi limit thermostat, the other red wire at the thermostat, then the red wire on the element, then the white wire on the element,
With the information from the previous post, and this additional information, you should be able to determine the fault in the heater circuit.
(if there's no voltage on the red wires at the thermostat, you'd have a broken red wire back to the control board, or a bad control board).
Good Luck,
Not so sparky (Oven Repair (including Ranges and Cooktops))
by sparky22 3/15/2013 4:56:30 AM(UTC)
