AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washing machine temperature switches from warm to hot
When my washing machine is filling, it will all of a sudden switch from warm water to hot. I turn the machine off then on again. I have warm water again but not for long. The hot comes back again. When this happens, a small stream of water comes out from under my washer. Not alot of water just enough to slowly get to my floor drain. Then it stops. If anyone has a solution to my problem, I would REALLY appreciate your response! Thank you, Kathy
Washer Repair
