3 Pages123>
kaf27033
#1 Posted : Monday, March 7, 2011 12:17:32 PM(UTC)
kaf27033
I have a Kenmore range that I was using last night to cook Lasagna. It was cooking at 400 for about 1 hour 40 minutes. I opened the oven to pull the lid of the pan off. After 5 minutes I returned and the top of the lasagna was burning. After looking in the over I could see the broiler element was on (hence the burning) and then the display showed f10 and I shut it off. Now when I try to turn on oven on to bake it starts heating with the broiler element.
From reading through other post I believe it could be the control panel, but thought I would post and see if there are anything I should try to diagnose the problem further. Thanks.
kaf27033
#2 Posted : Tuesday, March 8, 2011 11:16:49 AM(UTC)
kaf27033
Any thoughts on this? I believe the control board is the problem but am looking for any other thoughts before I spend the money to order it.
#3 Posted : Tuesday, March 8, 2011 2:02:54 PM(UTC)
The "F10" error code means that the control senses runaway temperature. The problem is a shorted relay in the EOC (aka a clock/timer) and the correction is to replace the EOC.
- The EOC Part number: AP4700815
kaf27033
#4 Posted : Wednesday, March 9, 2011 6:27:57 AM(UTC)
kaf27033
Thank you for the response. I will get the part ordered.
#5 Posted : Wednesday, March 9, 2011 3:21:44 PM(UTC)
kaf27033
#6 Posted : Thursday, March 10, 2011 5:38:23 AM(UTC)
kaf27033
Well I turned on the oven last night and too my suprise it is now working perfectly. Now the question is, do I replace the part or see if it continues to work. My only concern with replacing the part is that I wont be sure that was the problem. Has anyone seen where this could be a sporatic problem?
#7 Posted : Friday, March 11, 2011 6:55:22 PM(UTC)
If the error code you posted did show up once then most likely it will do it again.
If you did order the part from APP then you have up to 45 days to return it. I would keep the part and use the oven as often as possible for this period of time.
P.S. The return policy has been changed in 2011 and now you can return any part within 365 days!
Dave No
#8 Posted : Sunday, March 25, 2012 4:30:34 PM(UTC)
Dave No
This problem is very similar to the one that has started with my Kenmore range this week, except my model number (and manufacturer) is different. The symtoms are very similar - the range was baking fine and suddenly then the the temperature took off (blackening the dish!), the range started beeping away, and the error code F10 was displayed. I just tried it again today (without food in the the oven) and the very same thing eventually happened.
The range is Sear Kenmore Model 970-698380, Serial VF64956897. Can you please advise part number(s) I need to order? I might need to order?
Thanks for the hepl!
Dave No
Winnipeg, Canada
#9 Posted : Monday, March 26, 2012 10:12:47 AM(UTC)
Hi Dave,
In your situation you may want to check the oven temperature probe first. It should read about 1100 Ohms at the room temperature.
If the reading is incorrect, replace the oven temperature probe.
If the reading is correct, replace the EOC.
- The oven temperature probe Part number: AP3963654
- The EOC (aka control board) Part number: AP3965663
P.S. As far as I know APP does not ship parts to Canada. You have to have a valid US address to order parts from APP.
fsteddy1
#10 Posted : Saturday, September 22, 2012 7:18:56 PM(UTC)
fsteddy1
I have a kenmore range and i a m getting f10 alarms in the middle of the night for no reason my range was made in 2006 the model number is partly scratched all i can see is 970-60**85, mine cooks fine the alarm goes off when the oven is not in use can you tell me what ut can be.
thanks
3 Pages123>
