I have a Kenmore 80 series dryer that was working fine, with no problems until a couple of days ago. I finished drying a load in it, but the next day when my roommate tried to turn it on there was a soft clicking noise when you pressed in the starter button, but nothing else happened. It's b/w 5 & 6 years old I think. Any suggestion/advice/help?
The electrical outlet itself needs to be checked first to see if its delivering proper voltage. Then the first thing to check on the dryer is the terminal block that the electrical cord is connected to, and make sure the connections are ok.
Originally Posted by: Cyndi ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Kenmore 80 series dryer that was working fine, with no problems until a couple of days ago. I finished drying a load in it, but the next day when my roommate tried to turn it on there was a soft clicking noise when you pressed in the starter button, but nothing else happened. It's b/w 5 & 6 years old I think. Any suggestion/advice/help? I have this same problem with my 70 series. Checked wiring and replaced thermal fuse to no avail. What next?
Originally Posted by: ant1828 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have this same problem with my 70 series. Checked wiring and replaced thermal fuse to no avail. What next? You need to go back and do as I recomended to the other person in my earlier post. You need to check for voltage at both the outlet and the back of the dyer using a voltmeter to make sure its present. Remember you will be working around live voltage when doing this. If you dont feel comfortable with that then dont mess with it.
