10 Pages<12345>»
#21 Posted : Monday, January 31, 2011 5:47:33 PM(UTC)
Originally Posted by: mcdowell_112 Go to Quoted Post
I have a frigidaire range unit it will call for bake and broil but will not heat is the board bad?model #FEF326BB.The top elements work fine and I have power coming to the left side of elements but not on the right side.
Very likely the problem is a bad EOC. If you need the correct part number, verify the model number you posted. You missed some letters.
#22 Posted : Monday, January 31, 2011 5:49:34 PM(UTC)
Originally Posted by: jsw9674 Go to Quoted Post
Gene,
I have a similiar problem and it sounds like the EOC needs to be replaced. I heard a pop and the stove works, but not the oven.
Is this something I should be able to replace myself (as I'm fairly handy) and should I go through specific checks before purchasing the EOC? Also, any advice on what to do/not do when replacing the EOC?
Thank you for your time.
Jim
Jim,
Sorry I missed your post.
If it is not too late what is the complete model number of the range?
antb2112
#23 Posted : Tuesday, March 1, 2011 11:34:28 AM(UTC)
antb2112
Hello Gene
Wishing you well. I have a Firgidaire gas range/electric oven (mod#plcf489cc) in which the symptom is simply no 240v to bake element. The warmer, convection and broiler appear to work. There are two seperate relays, seperate from the EOC. Is there a way to test these relays? I don't know what's next. Thank you for your time. anthony
#24 Posted : Tuesday, March 1, 2011 3:42:39 PM(UTC)
Hi Anthony,
I'll be more than glad to help but you missed the last letter in the model number. Verify and repost it please.
antb2112
#25 Posted : Tuesday, March 1, 2011 6:17:34 PM(UTC)
antb2112
Ah-ha! Thank you, Gene for your attention.
I am missing a 'C'. Here is the whole thing.
Model#PLCF489CCC
I appreciate and look forward to your help.
anthony
#26 Posted : Tuesday, March 1, 2011 7:04:30 PM(UTC)
Anthony,
There is nothing else but the EOC what can cause such problem (wiring diagram), especially if there is only one 120 VAC leg to the Bake element is missing.
- The EOC Part number: AP2127066
antb2112
#27 Posted : Tuesday, March 1, 2011 9:05:01 PM(UTC)
antb2112
Gene,
Thank you very much! Confirmed my intial thoughts, I wasn't certain.
Thanks again!
anthony
#28 Posted : Wednesday, March 2, 2011 1:27:12 PM(UTC)
You are welcome Anthony. Keep us posted.
am81696
#29 Posted : Monday, March 7, 2011 11:11:17 AM(UTC)
am81696
I have an Electric Range model FEF366EMC. The broiler (top element) works fine. The stove top (all 4) work fine. But the bottom element in the oven doesn't work! What gives??? I can't live without my oven!
#30 Posted : Monday, March 7, 2011 5:19:53 PM(UTC)
The problem can be a bad Bake heating element, a broken wire(s) from the Electronic Oven Control to the Bake heating element or a bad EOC. You probably need an ohmmeter to check the heating element and wires.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FEF366EMC Frigidaire/range | AppliancePartsPros.com
10 Pages<12345>»
