Replacement parts for WHIRLPOOL EL5030VL0 | AppliancePartsPros.comSee the attachment for the wiring diagram
[COLOR="DarkRed"]I have replaced the thermostat, heating element, and thermal fuse. I checked the lint and the breaker and outlet. all are good.[/COLOR]
You also have a high-limit (Item 15 in Section 4) and a thermal cut-out (Item 6 in Section 4) in the heater circuit.
I do not know how you checked for power so that may still be an issue.
[COLOR="DarkRed"]Why wont the dryer heat?[/COLOR]
Could be a number of things, you have to do more troubleshooting.
[COLOR="DarkRed"]Maybe a resistor?[/COLOR]
No. The resistor only effects the timer motor.
Sounds like you are just replacing parts in the hope that it will fix the unit.
Lets try changing you from "lousy repairman" to un-lousy repairman.
Get a meter this will let you actually check parts before replacing them.
It is always best to try to use resistance/continuity when checking things as it is the safest way re: the machine is unplugged. Of course when checking for power this in not possible but you can check heaters, thermostats, fuses, switches etc using resistance (ohms).
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
First I would check the power. Just be very careful what you touch and that you do not short anything.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Note: If we assume that the new heater is OK then does the timer advance in an auto mode. If it does then your 240 is probably OK as the timer motor uses the 240 when in auto modes.
Then check the components in the heater circuit using ohms.
If the thermal cut-out (fuse) (Item 6 in Section 4) is blown open/infinite ohms) then get back to us as there are other things you should check before replacing it.
