AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
no heat generated in any of the 4 temp settings
Dryer is not heating up, no matter what temp setting I put it on. Also does not heat in timed or auto settings. Seemed to happen all at once. I replaced the timer (Manufacturer's Number: 3954449 Part Number: AP3100382 ) on 1-24-05 which was purchased from you and the service when ordering was super. Does it sound like it needs to be replaced again ? Or does it sound more like heating element ? Thanks
Probably the thermal cuttoff on the back of the unit behind the rear panel. Nat For more information post your model number
Dryer Repair
