Joe, I don't think it is the storage coil. I traced the water line coming from the blue solenoid as it comes to the front of the fridge, across the bottom, through a connector & up through the freezer door pivot. when I seperate the connector and push the dispenser lever I get full water flow. So it would appear that the blockage is between the dispenser and the bottom of the door. I tried using a little compressed air with no results. I am going to take the panel off the door again and see if I can get to the water connection. I noticed when looking at the drawings that there is a soleniod up in the freezer door - can you tell me what voltage that should read? Thx
Joe, I disregard the question about the solenoid, it looks like it is only for the ice door. It looks like there isn't any way to get to the water connection in the door without taking the liner off, is that correct? If the water line in the door is frozen, is thawing the freezer the only way?
Originally Posted by: FourMaxK1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe, I disregard the question about the solenoid, it looks like it is only for the ice door. It looks like there isn't any way to get to the water connection in the door without taking the liner off, is that correct? If the water line in the door is frozen, is thawing the freezer the only way? Max, Thanks for the update, you're doing a great job. I was really hoping it was not a frozen tube in the door liner, but you're test and diagnosis is on the $$$$. You can't really dismantle the door, to access the tube or dispenser, it's a "foamed in , solid core door", you'd just make things worse. You could try this instead, Disconnect the water tube fitting like before, and just let it defrost on it's own, heating the outer freezer door panel, with a blow dryer, may help speed up the process ? but be careful if you do. There should'nt be a lot of ice/water, but you should have a small container to collect the water from the tube, also keep an eye out at the dispenser, there maybe dripping from the fill tube, when the clog starts to defrost/melt. Hopefully, this is one of those "one time" occurrences, and you won't have to repeat this again. :) :) :)
Joe, OK, this is getting tedious - that and the better half is beginning to get tough. Heating the door isn't helping and that would only make sense if in fact it is foam filled door. I also tried blowing hot air into the dispenser and the tube at the bottom of the fridge - didn't expect much there either. I also took a wire and ran it up the tube hoping to hit some kind of blockage & the wire stopped at about the level of the dispenser. I then heated the wire slightly, again no luck. Thought about spinning the wire in an auger-like fashion, but didn't for some mechanical reasons & didn't wan't to chance doing damage to some component that I couldn't see. I am close to saying that this is a lost cause & would appreciate any help or suggestions. Thx
Originally Posted by: FourMaxK1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe, OK, this is getting tedious - that and the better half is beginning to get tough. Heating the door isn't helping and that would only make sense if in fact it is foam filled door. I also tried blowing hot air into the dispenser and the tube at the bottom of the fridge - didn't expect much there either. I also took a wire and ran it up the tube hoping to hit some kind of blockage & the wire stopped at about the level of the dispenser. I then heated the wire slightly, again no luck. Thought about spinning the wire in an auger-like fashion, but didn't for some mechanical reasons & didn't wan't to chance doing damage to some component that I couldn't see. I am close to saying that this is a lost cause & would appreciate any help or suggestions. Thx FourMax, I've searched all of my GE manuals and technical notes, This is the best I can do for you, DU800 - 900 Removing the inner door panel.doc (66kb) downloaded 14 time(s).I've checked all the parts diagrams and cannot find a part number for a water spout or water tube in the freezer door(as they had in some older/different models). At this point, it looks like you'll need to replace the freezer door. Part number: AP3861396
:confused: :confused: :confused:
Thanks for your efforts anyway. I have been corresponding on this forum with another who has a Kenmore and was able to slide the tube down out of the freezer door because it was in a channel. Is the GE totally foamed in, or can you tell? Thanks again.
Originally Posted by: FourMaxK1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for your efforts anyway. I have been corresponding on this forum with another who has a Kenmore and was able to slide the tube down out of the freezer door because it was in a channel. Is the GE totally foamed in, or can you tell? Thanks again. FourMax, I've attempted to check and find out if it was possible that the door may have had a conduit and a dispenser tube, Apparently, there is a water line sleeve inside the door ???? But, I can't find a dispenser body part number, which would indicate it's foamed into the door(not replaceable) and the water dispenser spout appears to be part of the dispenser body. The sleeve is only a few inches long, indicating the remainder of the water tube is foamed in place. I'm pretty much at a loss, at this point. :( :( :(
Thanks again Joe, I've gotta dumb question for 'ya. What if I find a way to pump hot air or steam up through the tube?
Originally Posted by: FourMaxK1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks again Joe, I've gotta dumb question for 'ya. What if I find a way to pump hot air or steam up through the tube? FourMax, Sounds like a good idea, Be careful though, you don't want to melt the tube, You might want to try using the water dispenser spout or try and clear it from both ends. If you succeed, please let us know how and what you did, so we can refer to your procedure in the future. Thanks, :) :) :)
thanks for your time. I will be out for 7 - 10 days and will update when I get back. I have an idea that might work. thx
