DaveR
#1 Posted : Saturday, October 4, 2008 2:21:07 PM(UTC)
DaveR
We've had this Woods frost free upright freezer for about 10 years and it works fine. But for some time (maybe since we moved it around) the drain water line freezes where it goes through the bottom of the rear wall into the overflow line. So the condensation water freezes and builds up in the bottom of the freezer. Should there be some insulation, or something else down there to stop this?
salhasan2003
#2 Posted : Monday, October 6, 2008 12:32:32 PM(UTC)
salhasan2003
Hi:
I have exactly the same problem with my side by side refregerator/freezer. Every once in a while I have ot us the hair drier to defrost it and remove chuncks of ice. If any one canhelp please e mail at salhasan2003@yahoo.com
Thanks,
libertyappl
#3 Posted : Monday, October 6, 2008 1:25:52 PM(UTC)
libertyappl
NO, But you can use a copper wire over the evaporator coils and place a straight part down into the hole to keep it from freezing. Although not recommended by WC Wood Co. Whirlpool says itcan be done and we have done several of the like that over the years.
If that doesn't sound appealing, get a defrost drain heater, part # SH250.
Nat
DaveR
#4 Posted : Monday, October 6, 2008 4:31:21 PM(UTC)
DaveR
What do you mean by "over the evaporator and a straight part down the hole" Is this the samr piece of wire so that the water runs down quicker instead of slowly running towards the hole? Please explain.
libertyappl
#5 Posted : Tuesday, October 7, 2008 4:07:54 AM(UTC)
libertyappl
With the copper wire you make a "shepards hook' place the hook over a coil on the evaporator and the long straight part goes down and thru the drain hole a little bit to keep it from freezing.
Nat
DaveR
#6 Posted : Tuesday, October 7, 2008 9:41:18 AM(UTC)
DaveR
Thank you very much Nat. I'll try that. Appreciate all the help.
ntchambers92
#7 Posted : Friday, March 12, 2010 1:29:15 PM(UTC)
ntchambers92
According to the Supco catalog "Tech Tip" - The SH250 Universal Drain Heater is designed for “series wiring connection” only. However, Supco Engineering told me this is incorrect. The SH250 is designed for "parallel wiring connection".
Guest (4)
