Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Checking various refrigerator components for continuity allows you to identify a failed component. For example, you can test your refrigerator defrost heater, defrost timer, defrost thermostat (at proper temperature only), fan motor, compressor relay, door switches, and other refrigerator parts. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
Originally Posted by: Admin / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Checking various refrigerator components for continuity allows you to identify a failed component. For example, you can test your refrigerator defrost heater, defrost timer, defrost thermostat (at proper temperature only), fan motor, compressor relay, door switches, and other refrigerator parts. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter Nice article. However, you do not even mention testing refrigerator parts in the actual article. Maybe you should stick in the intro paragraph to this thread into the actual article so it is a better and more searchable document for the future. Keep up the good work!
Type: Amana Model ASD262RHRW S/N 10271102EC
I dont here the compresor working, so there is no refrigeration at all. Help please.
kind regards Benji
Defrost problem How to check adaptive defrost with voltometr How to check voltage from adaptive to defrost heater if 110 v ?
Bohdan,
What is the complete model number of the refrigerator?
Can you post it in a new thread, please?
Maytag MZD2766GES Adaptive defrost white wire 110V,to red,orange wire to red 110v,yelow wire to red 40v I changed new adaptive defrost but nothing change/defrost still not working/ ,I checked defrost heater resistance and it is 30 oms and thermostad is open when it is worm,and is continue it is frozen
You can find the complete troubleshooting instructions in the Service manual(page 2-15). Here are the break down diagrams for the Maytag refrigerator Model MZD2766GESGene.
I need help locating the defrost timer on my 6 year old Amana refrigerator, model #DRSE663BW. I am having problems with the freezer coils freezing up, causing the refrigerator's temperature to drop, becoming to warm. It almost appears as if there is not one. Any help you can give would be appreciated.
robinson35, There is no defrost timer in your refrigerator. The defrost cycle operated by the Adaptive Defrost Control (#13 on the break down diagram) which is an electronic part. Remove the rear panel in the freezer and check for continuity the defrost thermostat (#11 on the break down diagram) and the defrost heater (#14 on the break down diagram). The evaporator coil must be cold at time when you check the defrost thermostat. Replace if any of them is open. If there is nothing wrong then replace the adaptive defrost control. - The part number for the defrost thermostat is AP4247331 - The part number for the defrost heater is AP84072 - The part number for the adaptive defrost control is AP177592 Here are the break down diagrams for the Amana refrigerator Model DRSE663BWGene.
Gene,
My Kenmore fridge (Model #363.9504784 and Seial #B02610841) has the same problem- Freezer fine, but fridge side warm. I've read all the other messages you posted. I don't have a manual or diagram showing what and where are the defrost system parts are and how to test them properly. I entered the fridge name and model and I'm not getting anything back. I would appreciate your help and guidance. Thank you.
Rudy
