Rank:: Member
I have a bosch dishwasher that had a custom cabinet face on the door. Can I switch that to a stainless steel door? I am changing cabinets and want to change the look. Where can I order one if possible? Thanks
Hello, There are two accessory s/s panels that you can purchase. The first model number is SGZ1005UC and the second is the SGZ1006UC. The only difference is the handle style. The 1005 handle matches the older 600 series ovens and the 1006 matches the current 500 and 800 series ovens. The Bosch website may have more info on this, but a Bosch dealer should definitely know more about them. KC
Rank:: Member
Spoke to Sears they can not find this model number or the part numbers you listed below. When I put the model number in on the Bosch website it does not come up. Any suggestions?
I have a bosch dishwasher that had a custom cabinet face on the door. One of the clips that holds the cabinet face has broke.I don't know what it is called or where to find it. Where can I order one if possible? Thanks Jennifer
Do you have the model and serial number? If so, I can find the parts breakdown.
Sorry, I realize this is an older post, but I'm searching trying to find out how to get this panel off. Bosch shv4303/u11
THIS FORUM IS DEAD!!!!!!! |
Thank you for the link. Took a look, pretty much says the same as I saw from the Bosch site....the for the SHV see the extra template sheet for instructions on installing the panel. I've e-mailed Bosch, if they provide me with info I'll post it here if someone else ends up needed it.
