dbern
#1 Posted : Sunday, October 5, 2008 1:24:36 PM(UTC)
dbern
My whirlpool Acubake oven won't heat up after the last time I put it thru a cleaning cycle. All other sensors apparently work - timer, clock, preheat setting (won't preheat also). Whats wrong?
Zanshin
#2 Posted : Sunday, October 5, 2008 1:34:52 PM(UTC)
Zanshin
Most likely the small thermal fuse in the rear of the unit has opened, and wont come back. It will need to be pulled out and open the back panel(very easy, couple screws) and you will see it at the top left side, check with multi-meter for continuity.
