misterfixall
#1 Posted : Friday, October 3, 2008 3:12:46 AM(UTC)
misterfixall
700 watt panasonic m/w taking 4 minutes to boil a cup of water ,where it used to take 2.5 min. installed new magnetron, made no difference. any ideas?
#2 Posted : Friday, October 3, 2008 4:23:34 PM(UTC)
Could be a high voltage transformer if the filament voltage is too low.
misterfixall
#3 Posted : Saturday, October 4, 2008 4:18:13 PM(UTC)
misterfixall
hi Gene .how do i confirm that the hv transformer is problem?
#4 Posted : Saturday, October 4, 2008 4:42:45 PM(UTC)
I would check the voltage to the transformer primary winding. If there is 120VAC ± 5% then the transformer is bad. If the voltage is incorrect but the voltage at the outlet is good, then the problem probably is a bad control board.
misterfixall
#5 Posted : Saturday, October 11, 2008 4:22:41 AM(UTC)
misterfixall
Hi Gene .i did some additional testing on this m/w ,checked various levels of power ,on level one m/w cycled on +off every 10 seconds or so, on level 2 it cycled on +of every 15 seconds .but from level 3 to 10 it ran continuosly .at all level it showed 150 volts give or take.i had a cup of water inside.it does boil after 3 1/2 minutes on levels 3-10 .there is no recognizable capacitor in this microwave . the transformer is combined together with a circuit board , there is the control board another smaller board and the transformerboard/ i checked for voltage to trans former with wires atatched ,there is a new magnetron ,the unit has 700 watts. thanks
#6 Posted : Saturday, October 11, 2008 1:35:22 PM(UTC)
Can you post the wiring diagram? It might help better diagnose the problem.
