rob53166
#1 Posted : Tuesday, September 23, 2008 12:04:04 PM(UTC)
rob53166
I have a built in single oven.Neither bake or broil elements will heat up.Control panel lights up and seems to work fine letting me set the time and temp as normal
libertyappl
#2 Posted : Tuesday, September 23, 2008 12:07:56 PM(UTC)
libertyappl
I would check the thermal fuse on the back of the unit, behind the rear panel. Part # 4451442 they tend to go out occasionally.
Nat
rob53166
#3 Posted : Friday, October 3, 2008 2:48:20 PM(UTC)
rob53166
thats what it was.replaced the thermal fuse and it seems to be working like it use to thanks for the help
