I'm tool time tim's clone and I'm lost!!! My front end load will not go into the spin cycle, leaving the stinking water in the drum? I had just replaced the drum and bearings with little difficulty. Washer worked for a day and then the funy "smoke"smell from the front and the water would not drain and no spin. Any help would be appreciated!!!!
Rank: Administration
Mikki, post the washer model number.
