rpc76
#1 Posted : Wednesday, March 2, 2011 10:44:35 AM(UTC)
rpc76
The right front burner won't turn off. After turning off house circuit breaker and turning it back on, the burner stays off until turned back on with its switch. Then won't turn off with the switch.
Help!
#2 Posted : Wednesday, March 2, 2011 5:52:44 PM(UTC)
Most likely the problem is a bad switch for this burner.
- The infinite switch Part number: AP4362288
jk1971
#3 Posted : Thursday, March 10, 2011 4:11:08 PM(UTC)
jk1971
I am experiencing the same problem with the front right burner and the left rear burner does not work at all (both large elements) the small elements work fine. If you look at the frigidaire factory parts catalog (http://www.warnersstellian.com/files/fec30s6a-ptsman.pdf) the two outer switches are labeled as detail 54(small element) and the two inner switches are labled as detail 54A(large element). However the cooktop dial controls are laid out as follows from the top to bottom on the cooktop.
Right Rear small element correct should be detail 54 and is
Left Rear large element correct should be detail 54A and is
Left Front small element incorrect should be 54 but is 54A
Right Front large element incorrect should be 54A but is 54
If this is the case, then the wrong switches were installed from the manufacturer on the left front and right front elements. Can someone verify this other than me? If it doesn't matter, then why are there different part numbers for detail 54 and 54A? I just want to make sure I order and install the switches correctly.
Thanks,
brh57
#4 Posted : Tuesday, April 10, 2012 8:11:48 AM(UTC)
brh57
I have the same problem with the two large elements on my cooktop. The left rear large element will NOT shut off until I cut the power. The front right large element will stay stuck on hi at times even if I turn the switch to low of off. I have to reset it by resetting the breaker. Am I looking at two bad switches or something else?
#5 Posted : Tuesday, April 10, 2012 11:38:38 AM(UTC)
Most likely the problem is a bad switches. The switches for both elements are the same because the size of the elements is the same.
Guest
#6 Posted : Friday, November 19, 2021 7:04:14 AM(UTC)
Guest
Rank: Guest
United States
I pressed button to turn a burner on and two burners went on in same time . My stove is a LG. What could have happened
