scott glynn
#1 Posted : Monday, October 8, 2007 12:19:37 PM(UTC)
scott glynn
200o Ge Front load washing machine. The machine will fill and drain but it doesn't move during the wash cycle nor does it spin to extract water. The belt seems fine. Any suggestions where to look next?
Entlord
#2 Posted : Friday, October 12, 2007 9:51:32 AM(UTC)
Entlord
Scott,
Does the motor run ? If not I would take a good look at the wiring on the door latch. You may simply have a loose wire. try jumpering it test. Good luck
