twice now my dryer stopped drying. every thing runs. I tested all the parts, there good. It just likes to have me pull the front off, look it over then start working. Last time while it wasn't heating I noticed the "dryness monitor" lights where both lit up. when it started working again they where off. It has a new thermostat and fan.I can find no loose wires.vent pipe is all new and clear.what do I look at next? thanks!
Test your breaker in the breaker box. Nat
:confused: The dryer runs. it's just some times it dries sometimes not.no rhyme or reason. Just something with the dryness monitor.
If it is intermitten problem, check all the wire connections in the dryer, one may be loose. Nat
