thompsonptpl
#1 Posted : Thursday, October 2, 2008 11:00:31 AM(UTC)
thompsonptpl
:confused: My Jenn-Air Radiant Cooktop ( Model CCE 3401) front large burner does not work. All other 3 burners work properly? What part needs replacing and how can I do it?
libertyappl
#2 Posted : Thursday, October 2, 2008 11:20:59 AM(UTC)
libertyappl
That could either be the element itself or the infinate switch (control) for the element. You would need to test each part to determine which you need.
nat
pjacobson2
#3 Posted : Thursday, October 9, 2008 8:10:14 PM(UTC)
pjacobson2
While moving an appliance in front of my Jenn-Air cook top I made contact with, and damaged, one of the control switches. The knob became free by way of the breakage of the switch shaft. The switch shaft broke in two at a groove in the shaft. I am assuming that I will have to replace the switch assembly. How do I get to it to change it?
