snarvaes
#1 Posted : Monday, February 28, 2011 3:04:07 PM(UTC)
snarvaes
Can you please tell me how to install it, from natural gas to propane.
Joe / APP Team
#2 Posted : Tuesday, March 1, 2011 11:54:14 AM(UTC)
Joe / APP Team
Snarvaes,
Attached is a copy of the general LP conversion instructions for a Gas Cooktop, used by most installers and service technicians.
Your Installation and/or Users manual, will have the same or additional information.
NOTE: Gas conversion from natural to L.P.
gas must be done by a qualified installer.
To convert the cooktop for use with L.P. gas,
perform the following steps.
1. Unplug cooktop or disconnect power.
2. Turn off gas supply to cooktop.
3. Use a screwdriver and remove the access
cap on the gas distribution valve.
4. Turn the access cap over so that the letters
L.P. are facing up, and then reinstall
the cap on the valve.
5.
To convert the cooktop burners for
use with L.P. gas:
a) Remove the grates and burner caps.
b) Remove the two screws from the burners
and remove the burners from the
cooktop.
c) Open the L.P. Conversion pack and
remove the contents.
NOTE:
Each burner, and its associated gas
valve, has a plastic bag containing an L.P.
gas orifice and a bypass jet pin. The bags
are marked with the burner/valve B.T.U. rating.
Match the B.T.U. rating on the bag with
the burner and valve locations (shown in the
drawings at the bottom right column) for the
cooktop you are converting. Do not open the
bags until you are ready to use them.
IMPORTANT:
Once removed, place the natural
gas orifice on top of the appropriate orifice
bag. After the L.P. orifice from the bag is installed,
place the natural gas orifice in the bag
for reuse if the cooktop is ever converted back
to natural gas. Also do this for the bypass jet
pins in step 6. Be careful not to interchange
the natural and L.P. gas orifices and pins.
d) Use a 7 mm socket wrench and remove
the orifices from the burner bases.
NOTE:
Place a small piece of masking
tape along the inside edge of the socket
to help hold each orifice in the driver.
e) Install the L.P. orifices in their appropriate
burner bases (be careful not to
crossthread or overtighten the orifices).
f) Reinstall the burners on the cooktop.
g) Replace the burner caps on the burners.
Good Luck,
Guest (4)
