Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, "clean" light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water. Replaced motor, still have light blinking..can't reset dishwasher...HELP!
Originally Posted by: keyarrow  Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, "clean" light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water. Replaced motor, still have light blinking..can't reset dishwasher...HELP! DISREGARD !!! After viewing all responses here, was able to get the correct buttons and sequence to reset: FOR: Model Number: KUDPO1ILWH6 Brand: Kitchen Aid Age: 5 - 10 years "Open door, within 3 seconds hit high temp scrub, energy saver dry, then repeat. Close door and press cancel." Machine goes through two minute run and clears the electronic display. THANKS !!!!!!!!!!
Originally Posted by: keyarrow  Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, "clean" light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water. Replaced motor, still have light blinking..can't reset dishwasher...HELP! Did you ever get an answer? I have same problem
