Originally Posted by: bbc3 Hello all,
Hope all is well with everyone. Seems my problems are not so easily resolved. The thermal fuse has blown 3 times now since I resolved the problem at the time of the last post here. So the issue seems to be, what is causing the thermal fuse to blow?
(1) I dont think there are any dwelling/house electrical issues contributing. I am getting about 118volts A/C at the outlet. One note is that it is an outlet on the same house breaker with other outlets in line. I believe the vacuum cleaner may even be run from time to time in this circuit. Was not thinking that was related though, as this is a "thermal" fuse.
(2) I have been using the "sani-rinse" which I believe heats the water pretty good in an extended rinse cylce. I am going to try to stop using that cycle and see if it helps. But really, shouldn't I be able to use it? So is it a programming problem on the main board chip??
Possible solutions: I was thinking maybe slightly insulate the thermal fuse to give some buffer. Or even get a fuse with a higher temp. This one is 90 Celcius, which I believe converts to 210 degrees F, or right below boiling. So perhaps get the next one up? Seems like while it would allow for too much heat potentially, it would still shut it down prior to total meltdown?!?
Any thoughts greatly appreciated. Joe?
Thanks in advance.
BBc,
I'm wanderring, myself.
You're sure you got all the wires connected and the connections are tight, correct ?
And you did use the harness that came with the fuse, correct ?
I"m sure you' ve checked for proper polarity at the junction box, on the frame,
You're pretty close to target on your temperatures,
Sani Rinse will heat the water to 155 dgrs.
High limit thermostat is rated at 180 dgrs.
The thermal fuse is rated at 195 dgrs.
(give a 10% "fudge factor" either way, and you'd still be in factory specs).
You should probably check the resistance on your heater element.
10 to 30 ohms resitsnce at room temperature, element cold.
in the dry cycle, with the element dry and on, you should read approximately 25 ohms after th element is on for a while.
The 118 VAC, is in a proper range, as long as the motor is running or the heater is on.
With the heater on and the motor running(sani rinse cycle) at 118 VAC, you should be drawing 5.5 to 6.5 amps. You should also check the voltage at the same time.
I can only think of a couple of possibilities,
Possibly, a sticky thermostat, weak thermistor or a low voltage problem, causing a higher than proper amperage draw.
For safety sake, don't insulate the thermal fuse, or run the unit without it, other than to test the unit, There is a great possibility of a fire hazard.
:confused: :confused: :confused:
