30tredog
#1 Posted : Wednesday, October 1, 2008 4:01:47 AM(UTC)
30tredog
when you turn the dryer on after 10 minutes the dryer will cut off, then when you push the start button it will come back on and run for another 10 minutes, and cut off again, and it will constantaly do that, i replaced the thermal fuse and the thermostat, because it would not cut on at all once i replaced those it began running
libertyappl
#2 Posted : Wednesday, October 1, 2008 4:17:39 AM(UTC)
libertyappl
Did you replace both thermostats on the heater box? There are actually 3 thermostats and the thermal fuse? which did you replace?
nat
kayakcrzy
#3 Posted : Wednesday, October 1, 2008 5:08:13 PM(UTC)
kayakcrzy
Check the door switch arm, and make sure it is hitting the door all the way. Tom ApplianceEducator.com
dryer cuts off after 10 minutes but will start (Dryer Repair)
by 30tredog 9/30/2008 5:51:35 AM(UTC)
