DREW255
#1 Posted : 16 years ago
DREW255
approx 2 weeks ago I wrote in about my washer not draining well, and I was told to check the pump and that I could get to it by removing the front panel, How do I do that,I'm a gas service tech, so I work on dryers etc. do I have to take the top off first(like a dryer). thanks
libertyappl
#2 Posted : 16 years ago
libertyappl
Near the bottom of the front panel there are 2 screws to remove the front panel. You don't have to remove the top. Here is the the breakdown on your machine, Model MAH5500BWW
Nat
DREW255
#3 Posted : 16 years ago
DREW255
I just checked for the screws, all I can find at the bottom is what appears to be clips or hinges
libertyappl
#4 Posted : 16 years ago
libertyappl
Sorry, wasn't looking at the model itself.
There are screws around to opening where your clothes go in. Then you can release the clips and the wiring, I'm going from memory here.....I have a set of these in the back of the shop somewhere!
You can see a bit of it from the breakdwon I posted earlier.
Natalie
DREW255
#5 Posted : 16 years ago
DREW255
thankyou for youhelp, I got the cover off, checked the pump for obstructions but found nothing, any ideas as to what is causeing it to not drain and not rinse well?
libertyappl
#6 Posted : 16 years ago
libertyappl
The pump itself may need replacing.
Maytag MED7500YW 1 Front Panel Removal? (Dryer Repair)
by Senator 10 years ago
GE Dryer front panel removal (Dryer Repair)
by Hyperventilate 11 years ago
Full Front Panel Removal (Dryer Repair)
by Inquirer 12 years ago
Front Panel Removal? (Dishwasher Repair)
by jim@vacuumtubesinc.com 13 years ago
LG Dryer front panel removal (Dryer Repair)
by gusnich 13 years ago
Front panel removal (Washer Repair)
by Dean2L2@AOL.com 13 years ago
Front Panel Removal (Dishwasher Repair)
by Edward Wieczorek 14 years ago
GE front panel removal (Washer Repair)
by blevdog 14 years ago
by bobets2@tds.net 14 years ago
by skullz 15 years ago
washer front panel removal (Washer Repair)
by zamboy 16 years ago
by Barbara Taylor 16 years ago
Maytag Dryer front panel removal (Dryer Repair)
by jkbatt 18 years ago
