kschmid
#1 Posted : Wednesday, October 1, 2008 11:04:10 AM(UTC)
kschmid
The inside door glass broke on the oven door when self-cleaning. I have looked at the glass replacement parts. They are linked by serial numbers. Mine begins with 33C137. Need help with the correct part to order. Also, since the glass broke while using the self cleaner should any seals or other parts be replace to avoid it happening again?
Thank you for your help.
libertyappl
#2 Posted : Wednesday, October 1, 2008 11:59:14 AM(UTC)
libertyappl
The part number for the glass is AP388748
You don't always need a new gasket/seal but if you want to order it the part number AP371040
Nat
