lisalisajoey
#1 Posted : Monday, October 8, 2007 5:46:09 AM(UTC)
lisalisajoey
The washer would not drian, so we removed the drain hose's inner and outer and flushe some gross stuff out of them. We tried to have a cycle go through using vinegar as the detergent but the washer will still not drain. What part may be out?:confused:
#2 Posted : Tuesday, October 9, 2007 1:04:58 AM(UTC)
You probably have a bad pump or stuff stuck in it. Pull bottom front panel and remove pump to clean out or replace. Parts available by Clicking on your model#
