slarson
#1 Posted : Tuesday, September 30, 2008 6:06:12 PM(UTC)
slarson
Hi, my dishwaher is stuck on and will only run the quick clean cycle. I can run no other cycle. I tried resetting the the breaker for 30 minutes, no luck. Has anyone seen this type of problem before?
Thanks,
Steve
libertyappl
#2 Posted : Tuesday, September 30, 2008 7:10:19 PM(UTC)
libertyappl
According to he tech sheet your quick clean cycle button is probably stuck.
Nat
slarson
#3 Posted : Thursday, October 2, 2008 5:26:56 PM(UTC)
slarson
Nat
Hmm, it’s a touch pad and the contact points are clean and free of moisture or corrosion, no way to get stuck, unless there is a micro switch on the control board that enages when the touch pad is depressed. I guess I'll just replace the control board.
Zanshin
#4 Posted : Thursday, October 2, 2008 5:38:46 PM(UTC)
Zanshin
Not the control board, you need to replace the touch panel, you have a stuck key.
