ningauble42
#1 Posted : Saturday, September 27, 2008 1:06:32 PM(UTC)
ningauble42
Wife left the freezer open and there was a lot of condensate in it. I emptied everything out, wiped it down (even taking the back off to wipe stuff in the evaporator area) and reassembled. Turned it back on at it just kept running. It got to below zero F in the freezer. I did turn it back off, waited a minute and then turned it back on and the compressor has not kicked in. I don't know if it needed a reset or there is something wrong.
I think I need a new thermostat, but could not find it in your parts area (by the way, nice parts area).
I found the defrost thermostat, but not the thermostat assembly, which I would think would be somewhere in the evap & freezer control assy.
Thanks for the help
Thurston
kayakcrzy
#2 Posted : Sunday, September 28, 2008 3:01:14 PM(UTC)
kayakcrzy
If your wife left the door open, the compressor is so hot it could fry an egg. The best thing you can do is unplug the refrigerator for about three hours, and then turn it on. That compressor needs some time to cool down. Tom ApplianceEducator.com
ningauble42
#3 Posted : Tuesday, September 30, 2008 12:55:59 PM(UTC)
ningauble42
Yes, I shut it down for a few hours. I also found that there was so much moisture in the frig that the defrost system was confused. It took a while for it to get the moisture out of the system.
Everything seems to be working fine now. $400+ saved!!!
Thanks,
Thurston
kayakcrzy
#4 Posted : Tuesday, September 30, 2008 1:19:01 PM(UTC)
kayakcrzy
There you have it. That is the way to save the cash. Tom ApplianceEducator.com
