II
I am reposting - I hope there is fix for this, the crok pot is starting to get old.
When turning the oven on, preheat starts and after a couple of minutes the clock is blinking at 12:00 as if the power went off and I have to cancel and reset the oven. This keeps happening until the oven reaches the temp. setting and then it stays on. This also happens w/ the broiler. This all seemed to start a couple of months ago when there was some problems with the power. We noticed the oven and microwave ( on seperate circuits) blinking when we came home for a couple of days. I called the power company and they acknowledged that they had a hardware issue and replaced something at the pole. The stove top with elec ignitor works fine. Hope its not to big an issue to fix. Thanks
