doutre
#1 Posted : Tuesday, September 30, 2008 12:05:50 PM(UTC)
doutre
Dryer runs and tumbles but does not heat to dry. Timer went out about two years ago and did not affect the drying process. So any ideas on what it might be. Our guess is the thermostat or the heating element???
Don't have meter to test. What should I do now????HELP!
libertyappl
#2 Posted : Tuesday, September 30, 2008 1:17:11 PM(UTC)
libertyappl
The first thing to do is go to your breaker box and turn off the breaker for the dryer wait a few seconds and turn in bck on and try the dryer again. If that doesn't work then do the following:
If you don't have a meter, then the best thing to do is remove the thermostats on the element housing and the element and take them to a local repair shop and have them test them. That way you get the correct part(s).
Nat
doutre
#3 Posted : Tuesday, September 30, 2008 3:47:58 PM(UTC)
doutre
Nat - Thanks for your reply. We borrowed a meter and the thremostat tested 00.6. There was no reading on the heating element. If it is the heating element how do I get it out of the machine???Breaker is OK.
Sheild around element appears to be welded.
doutre
libertyappl
#4 Posted : Tuesday, September 30, 2008 6:53:00 PM(UTC)
libertyappl
Remove the casing out of the dryer then there's one screw near the bottom and slide the element right out. Part # 4391960 or from this site AP3109438
Nat
Guest (4)
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by bselff 12/20/2011 12:58:18 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
electric dryer not heating (Dryer Repair)
by notimetowait 10/1/2010 6:26:06 PM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
by 18wheeler 1/30/2010 9:16:47 AM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not heating (Dryer Repair)
by Danske 11/23/2009 4:19:41 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
electric Dryer not heating (Dryer Repair)
by RJ Trucks 7/28/2009 10:52:36 AM(UTC)
