2 Pages12>
tvendett
#1 Posted : Sunday, February 20, 2011 11:35:22 AM(UTC)
tvendett
I have a Maytag Front Loader that I am getting an error message of (F, H). We looked it up and it means insufficient water supply. I have followed all the suggestions and the problem still exist. The washer errors out with the same code approximately three minutes into the cycle. Any help or suggestions would be appreciated.
sidfink43
#2 Posted : Monday, February 21, 2011 4:26:19 PM(UTC)
sidfink43
If it is filling correctly and if you have not changed out the flowmeter, try doing that.
Here is the part.
Part Details - WHIRLPOOL FLOWMETER, part number: AP4310720
tvendett
#3 Posted : Monday, February 21, 2011 5:15:44 PM(UTC)
tvendett
Thank You for the information, part is ordered crossing the fingers.
tvendett
#4 Posted : Saturday, February 26, 2011 5:36:05 AM(UTC)
tvendett
I replaced the flow meter and I am still having the same issue. Approximately 4-6 minutes into the wash cycle the error code appears F H. You can bypass the error by hitting stop than start. Any suggestions? Thank everyone for their efforts in assisting.
sidfink43
#5 Posted : Saturday, February 26, 2011 9:13:43 AM(UTC)
sidfink43
Well you can try the next obvious thing which is the water pressure level switch, again if you buy from this site and the part does not fix the problem you can return it.
Good luck, let us know how things work out.
Darn it all
tvendett
#6 Posted : Saturday, February 26, 2011 9:48:15 AM(UTC)
tvendett
I appreciate the info.
I do not think I will be pulling the part off since it is already installed.
I am going to order the pressure switch and give that a try.
Thank You
tvendett
sidfink43
#7 Posted : Saturday, February 26, 2011 12:32:01 PM(UTC)
sidfink43
Ok, good, hate to have the "try replacing parts until you see what works" solution but with the models that's about all you can do. It is what a service tech would do if he or she came to your house.
tvendett
#8 Posted : Saturday, February 26, 2011 1:40:48 PM(UTC)
tvendett
Are you aware of anything else it would be besides the Flow Meter and/or the Pressure Switch?
sidfink43
#9 Posted : Saturday, February 26, 2011 3:18:44 PM(UTC)
sidfink43
Well the main board is always a potential culprit, but let's hope you don't have to go there.
tvendett
#10 Posted : Saturday, February 26, 2011 5:05:33 PM(UTC)
tvendett
Wow I hope it is not the main board it is only 18 months old.
Guest (12)
2 Pages12>
