I need to open the cabinet of my Kenmore Calypso washer, so I can unclog the drain hose & pump. There are no screws at the corners of the control panel like some washers have. How can I remove the cabinet?
You wanna do this by tipping the machine back and there are 3-5/16" screws on the bottom plate..the cabinet does not come off like prior kenmores if you use a flat blade between prant panel and top there are a latch on the left and right and the lid flips up. Before tipping the machine back get as much water out of it as possible or it will come out the suds overflow. When that machine looks empty there is still about 3 gallons of water In it the old style pump is just like the older ken mores and the new one has 3 torx to take off and you clean very easily. But again can't stress enough there's is quite a bit of water in that machine even when it looks like theres not
Originally Posted by: murderurfriends  You wanna do this by tipping the machine back and there are 3-5/16" screws on the bottom plate..the cabinet does not come off like prior kenmores if you use a flat blade between prant panel and top there are a latch on the left and right and the lid flips up. Before tipping the machine back get as much water out of it as possible or it will come out the suds overflow. When that machine looks empty there is still about 3 gallons of water In it the old style pump is just like the older ken mores and the new one has 3 torx to take off and you clean very easily. But again can't stress enough there's is quite a bit of water in that machine even when it looks like theres not ____ Thanks. I greatly appreciate your help!
Not a problem check back let us kno how it went!
