weaselfx
#1 Posted : Friday, February 25, 2011 9:11:26 AM(UTC)
weaselfx
I received a new control board for the dishwasher. The electrical connectors on the old board are parallel but the new board has them at a right angle placement. I confirmed that the new board is current replacement. Should I just rotate the connector block to make sure that the colored wires match the color codes on the new board, ie gray wire to GY post, blue to BU and white with red stripe to W-R? They will align properly and make a proper connection. thanks
Joe / APP Team
#2 Posted : Friday, February 25, 2011 10:10:42 AM(UTC)
Joe / APP Team
Weasel,
If this is the part you orderred, you'll be fine,
Part number: AP3775964
Good Luck,
weaselfx
#3 Posted : Friday, February 25, 2011 10:49:04 AM(UTC)
weaselfx
THanks Joe. That was the part and I matched the wires. Still only partial response on the touchpad panel, Do I need a new control panel?
weaselfx
#4 Posted : Friday, February 25, 2011 10:54:29 AM(UTC)
weaselfx
actually, it looked like that but the part number on my APP receipt is WPL 8564542, but it shows correct part on your data base.
Joe / APP Team
#5 Posted : Friday, February 25, 2011 11:12:53 AM(UTC)
Joe / APP Team
actually, it looked like that but the part number on my APP receipt is Whirlpool 8564542, but it shows correct part on your data base.
Weasel,
Yes, you recieved the correct part, based on all the available information.
What was you're original problem, was it, "some buttons did not work" ?
Try this first,
Disconnect the ribbon from the new control board.
Clean the end of the ribbon off with alcohol, make sure you install it properly and tightly in the connector, put a thin coat of di electric grease or vaseline around the ribbon and board connector, and try again.
If that doesn't solve the problem, you'll need to order the touchpad assembly.
Part number: AP3138256
Good Luck,
control board connectors (Dishwasher Repair)
by weaselfx 2/25/2011 8:22:36 AM(UTC)
