I need to learn how to remove the Tower Spray from the present rusted lower dish rack and install it on the lower dish racj that I just purchased (part AP4316872). Thanks Art Rich
Originally Posted by: arichdevel  I need to learn how to remove the Tower Spray from the present rusted lower dish rack and install it on the lower dish racj that I just purchased (part AP4316872). Thanks Art Rich Art, This is the part you're referring to ? Part number: AP4113834
That is a "twist" on / off part, Twist counter clockwise to remove, twist clockwise to install. It can be difficult, I put the rack assembly on it's side,on the floor, "rock" the spray nozzle and twist at the same time. The installation is a lot easier. Good Luck, :) :) :)
Originally Posted by: Joe / APP Team  Art, This is the part you're referring to ? Part number: AP4113834
That is a "twist" on / off part, Twist counter clockwise to remove, twist clockwise to install. It can be difficult, I put the rack assembly on it's side,on the floor, "rock" the spray nozzle and twist at the same time. The installation is a lot easier. Good Luck, :) :) :) Joe, Thanks for the info. It took about 10 seconds to remove the Tower from the old rack and only 4-5 minutes to install it on the new rack. Thanks again. Art
Originally Posted by: arichdevel  Joe, Thanks for the info. It took about 10 seconds to remove the Tower from the old rack and only 4-5 minutes to install it on the new rack. Thanks again. Art Art, GREAT, It's our pleasure to help. Glad you're up and running, and it wasn't that hard a task. Good Luck, :D :D :D
