kriskeller9
#1 Posted : Monday, September 29, 2008 7:18:29 AM(UTC)
kriskeller9
Everything works except spin. However, if you "kick-start" the electric motor with a quick spin by hand, the motor runs fine. I replaced the motor already, but the new motor has the same problem as the old.
libertyappl
#2 Posted : Monday, September 29, 2008 7:57:02 AM(UTC)
libertyappl
The problem is probably in the transmission
kriskeller9
#3 Posted : Monday, September 29, 2008 8:47:31 AM(UTC)
kriskeller9
I checked the transmision....everything is fine there.
During spin cycle, the motor does not start rotating. With the belt off, I put the washer in spin mode.... If I hand spin it clockwise, the motor runs clockwise. If I hand spin it counter clockwise, the motor runs clockwise. There must be some "kicker" to get the motor started in the right direction. I just don't know what this "kicker" is? Anybody?
