My Dishwasher door will no longer stay shut. I presume that the latch needs to be replaced. Do I need to remove all of the Torx screws from the inside of the door to get at the latch? The picture shows the 2 screws closest to the latch. Are there instructions available anywhere? Thank you for your assistance. jofloz attached the following image(s):
Yes, you will need to remove all the screws around the inner door panel to access the latch assembly. Here is the part number for you. Part number: AP3179951
