irishlassie
#1 Posted : Wednesday, February 23, 2011 5:01:20 PM(UTC)
irishlassie
First was a lil drop and small amt of ice on shelves in refrig (drip from freezer). remedy: cleaned out freezer, removed part 603 as pictured here
Unit parts replacement parts for General Electric CTX18HABHRWW Refrigerator | AppliancePartsPros.com
cleaned out lots of ice underneath 603
adjusted door as it seemed that the seal was not tight
now more ice than ever before.
I dont see a drain in the freezer or refrig that could be clogged. The back is sealed and does not look accessible. I dont see a drip pan underneath the entire unit.
HELP!
#2 Posted : Thursday, February 24, 2011 3:28:26 AM(UTC)
I do not know if the drain is directly connected to the drain trough or it drains into the back of the fresh food section and then out. Odds are it is the latter.
Following are some of the parts which may help you get to the drain system and check/clean it.
Trough drain Item 633 in Section 3. You can see the hole for the drain.
Drain pan Item 751 in Section 3.
Drain tube Item 313 in Section 3
irishlassie
#3 Posted : Thursday, February 24, 2011 3:42:18 AM(UTC)
irishlassie
How do you get to the drain pan? Tip over entire unit??
? I dont see a 633....?
Thanks...
irishlassie
#4 Posted : Thursday, February 24, 2011 3:43:39 AM(UTC)
irishlassie
How do you get to the trough, tip over entire unit?
I dont see 633 in the photo.
#5 Posted : Thursday, February 24, 2011 4:01:28 AM(UTC)
Sorry, I messed up it should be 622.
It does not look like this unit has a front kick plate which is normally how you access the drain pan so you will have to try removing the rear cover (Item 267 in Section 2).
irishlassie
#6 Posted : Thursday, February 24, 2011 7:01:50 AM(UTC)
irishlassie
back of unit is totally sealed, doesnt look possible to open up without a real hassle...
irishlassie
#7 Posted : Thursday, February 24, 2011 7:52:51 AM(UTC)
irishlassie
Mission accomplished, drain was clogged in freezer and guk in the hose in the back. Thanks!!!
