so far i replaced the thermostat and the thermal fuse, because the dryer would not come on at all, and after i replaced those parts it started working, but now it only dries for 10 minutes and then cuts off, but it will start back up and continue to run but only for 10 minutes and then off again, and it constantly does that, can anyone help me
is there anyone that can help me
post says less than 1 year old ,i would call for warranty service ...and dont mention that you replaced parts as that would void your warranty....
Break down the dryer and clean out the lint within. Also the vent needs to be cleaned.
