kdog422
#1 Posted : Monday, September 15, 2008 1:44:14 PM(UTC)
kdog422
My 3 year old central air unit is having problems. It has one furnace/AC unit with dual zones (thermostats upstairs and down). When the AC starts up the outside compressor starts right up but the main furnace/blower unit kicks on and off about 6 to 8 times before it stays on (on for a second or two, off for a second or two). I'm told it could be a relay switch. Any other ideas? If it is a relay switch can a handy guy replace it himself?
icehouse
#2 Posted : Sunday, September 28, 2008 7:15:18 AM(UTC)
icehouse
Sounds like a voltage problem. Check the relay coil connections for 24V.
SublimeMasterJW
#3 Posted : Tuesday, October 28, 2008 8:37:00 PM(UTC)
SublimeMasterJW
Make sure all the connections to the electronic control board are tight and free of corosion.
