I am having problems with the dial cycle knob. The machine runs on certain parts of all the cycles. For example, on the permanent press cycle the machine won't run on the beginning of the cycle. Then when the dial gets to slower wash it begins. However, it runs when I press on the knob holding it down. If I don't press on the dial knob, it stops then. What would cause this? Thanks
It sounds like you have a broken timer.
